Old 07-30-2013, 03:34 PM
cjrolke cjrolke is offline
Default another 123 question (hydro newbie )
well I got the motor switched in to the 123 that I am working on
got it to run but not so much on moving
It was a little low on fluid so I added some hytran I had sitting
it moved a little bit forward and that is it
the drive shaft is spinning the pump is turning
one thing I noticed is on the pressure relief valves
one side will move up when the engine is running the other side is stuck down
I am currently soaking the valves with pb blaster to help free them up
if i could get some movement both in forwards and reverse i would feel a lot better about this one
should i keep soaking the valves and see if it will free up or split the tractor and then take the valves out ?
also i know i should put a new filter, drain the fluid and clean it out. could that be some of the reason she doesn't want to move?
i have 8 of these darn things and this is the first time i have had to work on a hydro
thanks
Old 07-30-2013, 03:39 PM
red56turbo's Avatar
I think your problem is in the relief valves. They should be in the "up" position. Keep soaking them and they should free up. Check over the linkages good and it probably wouldn't hurt to change out the hytran and filter. Relief valves still get my vote. Good luck and keep us posted.
Josh
Diesel Cub Cadets...........
Old 07-30-2013, 03:43 PM
thanks
that is what i am leaning towards
this tractor was a parts tractor that i decided to rebuild
i hate to see them turned in to that
for some strange reason i wanted a 123
( i might even make a tiger cub out of her some day )
Old 07-30-2013, 04:05 PM
I believe Josh is exactly right. If the valves are not all the way up she won't move (one valve for each direction).
I also agree that new fluid and a new filter wouldn't hurt anything.
Good luck!
Old 07-30-2013, 04:53 PM
STOP MESSING WITH THE RELIEF VALVES ON THE HYDRO - UNTIL YOU MAKE SURE THAT YOU HAVE JACK STANDS UNDERNEATH THAT CUB!!
I foolishly had a valve stick, soaked it in PB Blaster the same as you and tried to work it free while the cub was running and it had a mind of its own once that relief valve opened, knocking me down and running into the garage door only stopping because another cub got into its way!! I did something dumb and since then I learned the hard way. So, I am going to try to prevent anyone else from playing the fool, like I did! Safety first!! You are close to getting your problem solved by soaking the relief valves and changing the filter. The problem will be solved soon enough and everyone else who has commented has given you some excellent advice, and I concur with their words--I just wanted to iterate about safety first!!
BTW: Those are some excellent tri-ribs on the front of that 123, with some good looking rims!! I have the same on my 123 and love the way they handle/steer. Keep us posted on your progress.
Old 07-30-2013, 05:58 PM
thanks
I will put it up to start really messing with it
I have tri -ribs on almost all of my tractors
they steer so much better with that (and a nice cleaned up column )
