Old 07-24-2013, 05:06 AM
cdlong's Avatar
cdlong cdlong is offline
Default 1450 #1, another hydro problem.
Last week while mowing, I noticed it was slowing down more than usual, ( the longer I operated it, the slower it went), going up the 2 grades from my neighbor's yard to my yard. I also noticed the tractor was bucking, (almost stop, then resume speed), while backing down her driveway. Didn't really think much about it until this week. I use the lock on the shifter to maintain the same ground speeds as I mow several of the retired neighbor's yards. This week, while mowing my other neighbor's flat yard, the tractor was taking longer to get up to speed. Then when mowing my yard with the grades, I had to move the lock on the shifter, and move the handle further up to climb the grades. This tractor also picks up speed when going downhill. Enough speed that I have to pull down on the shifter and slow it down. I had changed the hydro oil at the beginning of the season because the rear cover plate gasket was leaking. I checked the oil level and it is correct and clear. I think the filter was changed 2 years ago when I put new springs and keepers in the trunion. Neutral is perfect, no tire movement. Any ideas what I need to look at? I intend to pull the fender pan this weekend and check the trunion.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 07-24-2013, 06:11 AM
My suggestion is...........Install a new Hydro Oil Filter. See..........Hydro Filters
Old 07-24-2013, 04:09 PM
cdlong's Avatar
Red face
Will do, thanks Roland! Should the oil and filter be changed annually?
Papaw
Old 07-27-2013, 08:19 PM
cdlong's Avatar
replaced the filter, NAPA Gold 1307. Cured the slowing up hill, but I still have the bucking in reverse.
Papaw
Old 07-28-2013, 06:52 AM
That could be a couple of things. First, examine your linkage to see if there is anything loose or sloppy. Make necessary repairs if needed. Next, I would pull the Relief Valves and soak them. Make sure they are clean and the internal parts have free travel. Blow them out real good and re-install them.
Old 07-28-2013, 07:35 AM
No, yearly oil and filter change is unnecessary.
Old 07-29-2013, 05:02 AM
cdlong's Avatar
I have looked thru the manual, but I didn't see anything for adjusting the linkage on a QL. Saw for the 100 series.
Papaw
Old 07-30-2013, 04:35 AM
cdlong's Avatar
I pulled both 1450s side by side yesterday afternoon and jacked up on wheel on each. The shifter and linkage on both seem to be fine. everything moves together on both tractors. I did notice on #2 that when the wheels were turning under power, and the brakes applied, there is a noise in the hydro with the pedal depressed. If I let up on the pedal, the wheels lurch slightly, forward if the hydro was in forward, reverse if the hydro was in reverse. and then apply the brakes again, no noise. The shifter must be moved 1 inch forward before the tractor moves and 1 1/4 inch in reverse before the tractor moves.
Papaw
