Old 06-30-2013, 12:03 AM
Learnin Learnin is offline
Default New from Australia.
Hi guys. Found your great forum while I was searching for a solution.
A friend has bought a new ride-on and said he would sell me the old one for $1000 AUD. (LT 1018-13AL11CG710 with a Briggs engine). When I arrived to pick it up, it would not start. We found there was no fuel getting to the carby. I checked the input line to the pulse type fuel pump & the fuel was getting to there O.K.
We figured it must be the diaphragm. So I decided to take it home and work on it today. The diaphragm looked fine but I couldn't feel any pulsing at the line while cranking the engine. I cleaned the top of the dipstick hole and blew smoke down into the crank case. Then I removed some covers & the throttle bracket-control & found this hole above the oil filter!
What would have caused this? Has the big end let go inside and punched the hole?
I was wondering if any of you guys have seen this before?
Thanks in advance.
Old 06-30-2013, 06:57 AM
Welcome to OCC.....
We have a few of your fellow mates from down under on here too.
I am not a B&S expert, however there should be someone else to chime in.
Old 06-30-2013, 06:58 AM
Old 06-30-2013, 09:27 AM
Welcome to OCC! Glad to have you!
Old 06-30-2013, 10:08 AM
Welcome to OCC
Looks like something inside tried to get out. Hope you didn't pay for it because it looks like the engine is toast.
Old 06-30-2013, 10:33 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
does oil or air blow from the hole? the bits in your hand look to be a little thin. looks like a thin area in the casting.
its good to have you here M8
Doug
Original , 100 , 125 , 582
