my 1882 steering shaft seal started leaking and I see in the parts breakdown that it's only available in a kit for $100.has anyone found a source for the seal by itself thanks dale
I ordered the kit from JD, it has a few extra seals just as a heads up. It was just shy of $60. The Deere number was AM107078. Your going to have to pull it apart so you may as well rebuild it. This is a good thing to read before pulling it apart. http://www.mytractorforum.com/showthread.php?t=208848
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
I too repaired a 2072 with a kit for a JD. That kit cost less than $50.00 bucks and had all the seals needed and as already said had a couple extra seals but it stopped the leak. There may be purists that will only buy genuine cub parts but when one that takes care of the problem is available for about half the price I will take it. I also just bought a rear hydro seal. Cub wanted over $20 and I got the exact same seal from NAPA for just over $6.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
I got the same kit from "The Green Parts Store" online, shipped to my door for $45. Looks like it's a little more now. Or if you have a Parker store near you their part number is SK000097.
http://www.greenpartstore.com/search...15&search.y=10
Parker as in the manufacturer of the hand pump right? ...... That's what I was going to say. Get me the numbers off the pump and I might be able to get a kit. If these are the Parker numbers I'll call my hydraulic supplier!
Jonathan, Oak is correct on the number as it is the same one we used on the 2072. And many others use the same.
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
