Is the added fluid capacity of the 26x12 tires worth the loss in surface pressure and overall gear reduction over the 23x10.50 tires?
I would guess that all depends on what tractor and what your trying to do with it.
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
I like my bigger tires BETTER!!
![]() ![]() These stick like glue, but, they are radials!! ![]() NO fluid needed!! ![]() |
129, ultimately It will be plowing as well as other heavy ground work.
I think I'd add weights (and fluid) to the 23 inch tires rather than go to the 26 inch tires, especially for ground engaging work. Not only will the 26 inch tires be a tight fit, you can't put chains on them like you can on the 23s (due to clearance issues) for pushing snow.
As you've stated, you will also lose mechanical advantage with the larger circumference tire.
![]() Quote:
Any thoughts on the 24x12x12 ags on the market by chance?
