My #127 steering has a distinct wobble,
Side to side= 1/2 inch. Up &down = about the same. ![]() How much time do I have before it goes kaput? Is this a big job to undertake? I have no clue? Any suggestions? NIK,
It dont cut grass, but its yellow. |
Check wheel bearings for tightness/condition same for spindles.
Check tie rod ends for tightness/condition Check axle pivot pin for tightness/condition. Check lower steering draglink ends for tightness/condition Check lower steering sector cam follower for tightness and condition. Could be any one of those and/or a combination of 2 or more. Just may be time for a steering/axle/spindle/bearing re-hab. Just finished up doing a 1250 today If Ya have to hire someone to do it and furnish parts I could forsee this job costing upwards of $100 maybe more just for parts alone if you use good quality stuff. Good luck!! Dave S. |
Just a little more info on what is loose and just maybe we can give you an answer. No warranty expressed or implied.
Sounds like the bearings may have come loose in the steering box with that much up and down movement on the steering wheel. My 123 did that before I ended up rebuilding the steering box, sounds like it might be time to dig in
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
I got a kit from ccspecalties which was $35 shipped, included the super steer upgrade, a new foam seal for the top of the column and a ball bearing to replace the plastic bushing that is on the top of the column.
I also bought 4 new rod ends from mcmaster carr $21 shipped. I got the stock style ones, you can get the upgraded HD ones for about $10 more My bearings and cups were good, so was my cam follower but if you need those parts its $40ish for the bearings/bearing holders and $30ish for the cam follower. Axle pin is about $20. The grease in there probably looks disgusting too. Pop the column, take it apart and asses the situation. Worst case you will probably need to spend about $150 in parts to get it to better than stock condition and it will be that good for another 40 years. If most of the stuff is good youll be out about $50-$75. I didn't want to do this kind of stuff on my cub when I started the refresh (planned on only replacing what was broke) but that went out the window about 2 weeks into it.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
Turn the wheel and look at all the linkages to see where the slop is. The rod ends are an easy and cheap fix.
Steve, Former multiple 149 owner. Left the tractors back east when we moved to Nevada. One went to South Jersey, the other to Long Island. |
![]() Quote:
Thanks guyzzzzzz for the input. NIK I think I can do something like this????
Here is a link to a topic that has information on rebuilding a steering column for my 70:
http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick This should show you what needs done to yours.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
![]() Quote:
Well, just sitting there I can move my steering wheel, side to side. I fired it up & took it for a spin & the same. Just that the steering wheel can be moved as stated. Front end is tight just the wheel ![]() Nik
