Will a 149's lift work on my 1810, or is there something in the way. I know the handel will have to be changed, anything else?
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
It will work but you have to get a ported hydro pump also. The steel lines might work but I am not sure.
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
Adam, the 1810 has a ported pump the last time i checked. I'm trying to get a hydro lift for the 1810 since i want to build a cat O lift for the back.
Ok, I didn't know that, The steel lines are bent different on the 149 than like on my 1811. I don't know if they will interfere with anything though.
I'm not sure. Never had a tractor with hydro lift.
