Old 01-23-2013, 08:18 PM
Donovan M.'s Avatar
Default 1250 hydro lift
Will a hydrolic lift off of a 1711 fit on a 1250. I know the valve handle will need to be changed any thing else.
Donovan:
62' Original-fenders
Old 01-23-2013, 08:43 PM
cub123's Avatar
cub123 cub123 is offline
They are quite a bit different, cylinders are different lengths, as well as how they mount I believe. Plus if the 1250 doesn't have a ported pump you will need it as well. I'm sure it could be done, I think you would have to drill the frame for the cylinder bracket, and use the rockshaft from the 1711 of course.
Not sure on clearances for the fatter cylinder, but I think it would fit.
This is the 1250 hydro lift
And the 1711
Old 01-23-2013, 08:51 PM
Donovan M.'s Avatar
1250 is ported, just no hydro lift.
Donovan:
Old 01-23-2013, 09:34 PM
Totally different parts and not worth trying to make them fit.
Old 01-23-2013, 09:48 PM
Donovan M.'s Avatar
Yeah, im getting a new lifting mechanism for the tractor. So im sticking to the manual lift.
Donovan:
