Old 11-25-2012, 04:22 PM
Default What happened to my "reverse" on my 782?
I parked my 782 back in July-August and finally got it started today, but when I did, there was no reverse whatsoever! I filled the transmission with fresh Hy-Tran and it has always had a really strong reverse before I parked it. Everything runs excellent on it, except no reverse. Could that be my hydro filter being clogged? Help-I've never experienced this kind of a setback before!!
Thanks in advance for your advice and interest in my thread,
Old 11-25-2012, 04:25 PM
cubs-n-bxrs's Avatar
Sounds to me like one of your hydraulic dump valves is stuck.
Old 11-25-2012, 04:30 PM
Wow, thanks for the fast response Cubs-n-Bxrs! Ok, they are automatic dump valves, so how do I remedy that if it is the case?
Old 11-25-2012, 04:34 PM
To be sure that is the problem you can swap them and if after you swap them you don't have forward then it's time for new a new valve.
Old 11-25-2012, 08:28 PM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
Take both of the valves out ant tap them on a hard surface on the nut end. Reinstall them and try your hydro. It should work just fine. I had one stick on one of my 782s and it has not done it since.
Good luck.
Brian
Old 11-25-2012, 10:43 PM
Good luck.
Brian
Wow, I hope that is all that I need to do to fix this problem. When yours got stuck, did you lose forward or reverse? This is my first experience with auto relief valves. I've had the manual ones stick on me before and managed to loosen them up with some PB Blaster, but aside from my zero turn, this is my newest one--still IH built. Thanks for the advice!
Old 12-04-2012, 09:35 PM
Good luck.
Brian
Haha....I did that and on the third tap the whole unit flew apart into about 5 different pieces!!! I think it had been repaired and and had a very weak weld on it and the other one was definitely stuck---the spring is sideways and through the holes!! Two more automatic valves are on the way and I'm very glad that I found out what a horrible shape those were in. It probably would have worked if the PO had taken better care of this machine.
