Old 10-24-2012, 01:19 PM
lilkrou lilkrou is offline
Default Fluid leak
I have fluid leaking from the from driveshaft output on the transmission. Over the summer I drove through high weeds and they got caught around the driveshaft and were plugged up in there pretty tight. I was able to remove the weeds, but it is also leaking there (from the pressure of the weeds being wrapped around it?). Anyhow, I have identified that the part that I need replaced is IH-377959-R91 (Oh yea, this is a '63 Original!) and have found that it is NLA. What is the process of finding a replacement (this is my first foray into NLA parts on a tractor)? Any help is appreciated!
Tony
Old 10-24-2012, 04:01 PM
Ok, so what I'm taking from your description is that you knocked the seal out the reduction housing? Is this a seal that you speak of? If so, did you cross reference the numbers to see if the seal is available from other sources?
Old 10-24-2012, 04:27 PM
Yes, the seal is loose or something in the reduction housing. That is the question that I was looking to get answered. Where do I find some sort of a cross reference to go to in order to find a part that may be purchased?
Old 10-24-2012, 04:28 PM
Take that number over to a bearing house or ask the sponsors above
Old 10-24-2012, 05:52 PM
FWIW seals usually are listed by:
Shaft size
Outside Diameter
Width
then type of seal/style
----but it's prolly a std. seal.
Many times I go to my local (very close by) Green Ag dealer and get seals for a lot of my off color equipment.( usually do it online)
Napa is helpful also.
luck!
