Old 09-03-2012, 10:25 PM
wally67's Avatar
wally67 wally67 is offline
Default 582 command swap
Well I'm finally getting around to swapping a Command into my 582. I picked up this decent 582 a while back the 16hp Briggs still ran good, but I have really wanted to do a Command swap into one of these for a while. I plan on using this tractor for tilling, mowing, and plowing so I will still need to use the stock size front PTO and will need to run a creeper gear on it. I am currently in the mock up stages but have found that the front PTO off of an 1811 will fit the command engine (the engine I am using is out of a 2185 the mock up engine that is in the tractor is out of an 1864 pretty much the same engine but different exhaust).
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow.
Old 09-03-2012, 10:35 PM
wally67's Avatar
The first thing I wanted to tackle on this project was the wiring. Since the briggs uses an ignition system similar to the command (no points) the wiring was the easiest part so far I used the wiring diagrams from both tractors and it was really pretty simple. I did have to cut the harness on the 582 open to move some wires that ran to the solenoid and battery at the back to the starter solenoid at the engine now. I will get some pictures posted as soon as I get everything soldered together.
Old 09-03-2012, 10:57 PM
wally67's Avatar
The next project was the engine spacing. Since I need to run a front PTO the PTO needs to be mounted in the same location as the old so you will have to make some sort of clutch driver spacer I used two command clutch spacers/hubs and a clutch driver, all parts were from Lakota racing but I did have to have 3/16" machined off of one of the spacers to get everything where it needs to be. On the engine plate I just moved the rear bolt holes 3/4" forward of the two rear slots. If you have any questions let me know
Old 09-03-2012, 11:02 PM
wally67's Avatar
I had a little time this weekend to get the rear axle out, get it cleaned up and got the creeper mounted on it. I am also replacing the aluminum rear axle tubes with a set of cast iron ones.
Old 09-03-2012, 11:11 PM
Very nice! Please keep the pics coming.
Old 09-03-2012, 11:15 PM
Nice work Wally. Will be following this one.
Old 09-03-2012, 11:38 PM
wally67's Avatar
Thanks guys I still have a couple of things to work out on this, one is the throttle and choke cables (im going to need some longer ones) and the other is the exhaust I could run the stock 1864 muffler but would really like to build a custom 2 into 1 header and exhaust stack exiting out of the right side but I dont want it to be too loud so I was thinking maybe a harley drag pipe baffle of some sort. More pictures and info to come. Wally
