Bought a new set of wheels from a fellow member but they looked a little rough. So they spent the night swimming in the electrolosys tank. Then sanding and the wire wheels, followed by three coats of rattlecan white primer. That's all before it got hot. Went out this morning and started the top coats and my danger paint is drying faster than I can spray it. I'm just using valspar gloss white, because I like how it looks. Here is the pic as they came straight out of the box.
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment. ![]() |
I cleaned up my rims the old hard way.
![]() The steel is in the white after handsanding and was rusting, so I primered with this primer. It realy was nice primer. Good luck!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
I was working on it the old way but the inside tire grooves were heavily scaled with rust. The electrolosys worked awesome for getting the scale and rust out. I didn't take the pics after the tank, had to get them cleaned and primed pretty quick to keep the rust from forming back on them. I'll post some pics after the 6 or 7 coats of gloss white. I will say I used rustoleum white primer on the faces, and grey on krylon grey primer on the insides and the white is is doing a much better job. I'm rather excited about getting them done, it will give me an excuse to buy some new tires for them..
nice they look good get them finished and put them back on the 126
yes, the old hard way. i think tommy james and the shondells sang a song about that, dragging the line. you will want to have a clean bead on the rim, but i plan on using tubes so i can load them.
![]() ![]() ![]() a basket pully shot, but the same with the rim. nice work, keep us posted.
Looking good, Earl! Can't wait to see them finished.
That stuff is good ! I suspect it's a diluted hydrochloric acid, because it sure burns if you get it on your hands....at least the liquid version does!
John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
