Old 06-07-2012, 07:39 AM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default Early 3/4 digit Original Questions...???
Did any of the early 3 or 4 digit serial number orginal have creeper gears?
More specifically could an early 3 or 4 digit O's frame have a hole in the frame for the creeper gear lever?
I'm trying to better understand the indicators of early O's without actually seeing the serial number.
Thanks!!
Old 06-07-2012, 08:10 AM
Darrell Darrell is offline
I have had two early digit O's and neither one had a hole for the creeper or a slot for the steering in the dash tower.
Not sure if there is a serial no. break for these or not ?? I do know of some people swapping rearends to make an early O , it is an easy swap.
Old 06-07-2012, 08:28 AM
drhntrrmw's Avatar
Could you explane the slot in the dash tower for the steering?
I have never heard of that difference.
Old 06-07-2012, 08:35 AM
It is a half moon looking slot in the right side of the dash tower. Early tractors didn't have it.
If you do a search i am sure you could find some pics. to compare. Someone on here may have some pics they can post.
Old 06-07-2012, 09:35 AM
I also look for collared spindles, earlier starter generator bracket, and the small slot rear wheels.
Old 06-07-2012, 10:16 AM
mmzullo mmzullo is offline
Most creepers where dealer installed so your going to have a man made hole for the creeper. Early O's also had the regulator on the side of the dash tower. I had 3 digit but was pull start so it had no regulator. Collared spindals was an other early thing. Casting #'s in the rear and front grill was an other way to tell an early O's. Also the thin front axle. People do make fake early O's by changing the front trans reduction gear. Also collared spindles are being changed out.
So if your making one or buying one look close to casting #'s. Especially if your paying a lot for one. Do your research.
