I took the engine out of a new to me 1450 (very late model) today, and as usual the ISO mounts were shot.
OK, I have read the Technical Section "Quietline Motor Rail Modification" http://onlycubcadets.net/forum/showthread.php?t=4630 Now I still have a couple questions. The drawing calls for 1.50" x 8.50" (8.75") x 1/4" Below in the writeup, 3/8" thick is mentioned!! ![]() Which dimensions should I use? I am leaning towards 1.50" x 8.75 x 3/8" if that is OK!!?? (I love belts AND suspenders!!)In the "Iso Mount & Snubber" section it says to shim the snubbers to 0.06" to 0.12" Is there a correct dimension of frame to ISO rail given anywhere?? ![]() It seems like this could vary with the amount the ISO mount is tightened. Am I overthinking this?? ![]() My ISO mounts were so bad the right rear bolt went through the blower housing and the oil pan was cracked!! I had another pan! As everything was so far off when I got the tractor, I would really like to know I set the frame to rail dimension properly. |
I used 1/4 last year when i did mine
And for the clearance the snubbers are not touching the frame. Thats why there is a clearance the mounts are bolted down tight on the frame so there is no clearance to measure. I should just be the height of the medal insert inside the mount
David 1200 w/ 44in deck 1000 w/ yanmar diesel.... in progress |
Yikes worn thru the blower housing.
AFAIK....there is NO dimension for the height of the lower ISO mount, to give you a clearance from the frame to rail. It is assumed if you have new ISO mounts, then you have the correct clearance. In addition, the gap on the snubber would give you and pretty good idea if the lower ISO mounts are with proper height.
I've got a 1650 that I am going to do a cradle mod and am using 1/4 inch material which looks pretty beefy to me.
Also sending you a PM Good luck, Bill |
Don't ever want to run out of Mod Bars!!
