Old 04-22-2012, 09:27 PM
LiamD's Avatar
LiamD LiamD is offline
Default 1450 The results are sparking!
Hi All,
I recently picked up a 1450 from a friend, he stated he thought that it needed a new starter. I installed a new battery and it runs great. Fast forward two weeks and I noticed that it sounds as if the battery is getting low on charge. Tonight I checked voltage while running at the battery and it is at 13.59 volts seems right. the throttle cable quits, so i remove the side panel and prior too me changing the mounts i notice that the throttle and choke cables have worn into the engine tin work behind the flywheel and the choke cable is arching against the tin. I moved the cable away from it, shut it down and upon trying too restart I notice that the choke cable is now arching at the dash on the outside near the steering wheel. Any suggestions on where too start. A quik once over and I didnt notice any wires even close too the choke cable. Could it be a bad ground by chance? Any opinions are appreciated.
Thanks, Mike
Old 04-22-2012, 09:32 PM
From the manual section here on the forum
Old 04-22-2012, 09:38 PM
LiamD's Avatar
Thanks Jeff,
I have the wiring diagram already, but I appreciate that.
Mike
Old 04-22-2012, 09:41 PM
There is supposed to be a #8 wire from the bolt on the starter mount leading to the chassis.
Is that missing!!??
Old 04-22-2012, 09:49 PM
LiamD's Avatar
Thanks Cadplans,
I will check that but I only noticed one wire on it and it was part of the wiring harness.
I'll check that tomorrow.
Thanks, Mike
Old 04-22-2012, 10:05 PM
2 of mine have a 8 inch wire from the starter mount to the bolt holding the grill shell. It is not in a harness bundle.
Old 04-23-2012, 09:52 AM
jbrewer's Avatar
jbrewer jbrewer is offline
If the dash is fiberglass, I think arcing to ground thru the choke/carb cable makes sense. (ISO mounts do more than insulate from vibration!)
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
