Hi
What would be the normal rpm to run mowing - say up in rabbit position? And what would be the low idle rpm to want in the turtle position? I want to try to adjust my cables on my 16 hp kohler to good work positions from idle to work levels. Also, where is a diagram to show hook my drawbar from the lift connection back to the 3 point hitch lift. I am wondering just how to fit the movable piece at the end of the drawbar to the hydraulic lift. Thanks Earl |
Duke
I appreciate the help. Are you running 3600 WOT when you are plowing ground? I have plowed much ground as young feller many years ago using Farmall's like H's, M's, MTA's, and others - tobacco, corn and garden ground. It is nothing short of amazing to me to see you plowing ground with a 1650 in the videos I watched yesterday as well as you did. I had heard the plows mentioned but still wondered how good a job could be done with a cub cadet. Those videos showed you cutting a good furrow and turning over a good piece of dirt. Thanks again, Earl |
The Service Manual states for the "best" cooling of your engine, running at WOT is recommended. I always run mine WOT until I am ready for a shut down.
![]() These are so well built and designed that they are true work horses. I've never been disapointed by the work they can do. Quote:
