Last week I set my engine to the proper RPM's for high and low throttle. Now Im noticing that if I am on high throttle and I move the hyrdo lever forward a little to go slow, it keeps moving forward to high speed by itself. I was wondering if this is normal or another little project for me to work on? Thanks, Mark
Sounds like another project. Possibly trunion and or hydro linkage repair/adjustment time.
http://cubfaq.com/trunionrepair.html
My 982 does that - takes me on a heck of a ride. I'm thinking that the linkage is a little loose.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
Thanks for the info and for that repair sheet. Guess I will be taking the tunnel cover off today and have a look see.
Also have to remove the fender pan.
You can tighten up the hydro lever. 149's had 2 different styles.
Early style has more of a clamp you can snug up. Later style has a nut straight on the bottom of the shaft that you can tighten. You will see once you get the tunnel cover off. |
