I am working on rebuilding the steering on my 109. I upgraded the jam nuts to a thrust bearing and nylock nut and also replaced the plastic bushing in the top of the column with a shoulder bearing. The question I have is what kind of material is the D-shaped seal made of ? This steering box either did not have one or it has long since descentegrated(sp).
72 Cub Cadet 109 S/N 435384 ^^^undergoing a refurbishment^^^ 71 Cub Cadet 149 S/N 410929 |
It is kind of a thin foam like substance. Not very hearty.
I am thinking of cutting one out of an old inner tube. Any reason it would not work?
that might be a little stiff and could cause it so rub to hard and wear through the steel piece. i used some crafting foam, from any craft store. Hope this helps
Cubs: 2xOriginal, 100, 125, 2x127, 147, 128, 2x 66 Sears Suburban, 66 Sears Custom 6, 64 DB 725 |
You can get that part at the dealer still for a song and dance. I rebuilt the box in my 123.
I use that material that contractors use on houses between the concrete stem wall and the wood frame. It is the right thickness and seems to last a long time.
