Old 03-23-2009, 08:35 AM
ihc353s's Avatar
ihc353s ihc353s is offline
Default Differents of Kohler KT 17???
Hi Guys,
now, i've a new Question.
Whats the Different between the Kohler KT17 Series 2, with Spec. Nr.: 24301, and the Nr.: 24302?
I saw Parts of it in some US Ebay Auctions.
Can i buy this Parts, and will this Parts fit to my Block, Nr.: 24302?
Look at the Pic of my Cylinder, can i own this with this crack, after rebuild, or need i an New one?
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 03-23-2009, 08:44 AM
Willy Willy is offline
Captain Obvious
Georg,
I'm no expert, but I wouldn't use that cylinder. There's too much of a chance that the skirt of the piston or rings will come down into that area and chew itself to pieces.
Find a new jug, they are cheap and you'll be much better off in the end.
-Ray
Old 03-23-2009, 08:47 AM
Georg:
Kohler Spec Numbers:
24301 = Was made for John Deere
24302 = Was made for IH Cub Cadet
I would venture to say, that these motors are identical EXCEPT for the Crankshaft. The diameter of the crankshaft on the PTO end will be different
I had a small chip out on the bottom of one of my cylinder jugs also. The small chips did NOT effect the piston travel. So, the jug was bored .010 over and I have had NO problems. You can measure to see if the piston travels or is exposed to the "chip out area".
The jugs from the above Kohler Spec numbers would be interchangeable.
Old 03-23-2009, 08:57 AM
murphycc
Guest
Posts: n/a
Georg
I have a spare Kt17 also with a broke rod, I will tear down in a couple of days and if the jug is good you can have it. Make it simple on me and I'll ship USPS Priority International, just pay the shipping.
Scott
Old 03-23-2009, 08:59 AM
murphycc
Guest
Posts: n/a
Georg
I'm not sure if jugs are interchangable from side to side, I think they are but I'm not sure, which of yours is damaged?
Scott
Old 03-23-2009, 09:07 AM
Scott:
YUP...The jugs are the same.
Old 03-23-2009, 09:29 AM
ihc353s's Avatar
Thank you for the answeres,
@Murphy: Do you want to repair, or to Part the Engine, can i get the good Rod, and the Piston too?
Tomorrow, i will go to a Engine rebuilder, and look, if we can grind the Crank free of the Aluminium Parts, to get back the standard size.
I will make a reply, if i know more,
mfg Georg
Old 03-23-2009, 01:24 PM
Originally Posted by murphycc View Post
Georg
Scott
Check the manual to be sure, but I think that they are NOT interchangeable starting with the series II. They are machined differently for the valve seats.
Old 03-23-2009, 03:44 PM
murphycc
Guest
Posts: n/a
The only manual I have is for the 18M, if he needs the left I'll send him the left. My spare is a Kt17 not a seriesII.
Scott
Old 03-23-2009, 11:47 PM
murphycc
Guest
Posts: n/a
Georg
I have one good jug with piston to send you if you want it. The other looks exactly like your damaged one. This is a KT17 Series II, I was wrong when I said it was not a Series II. I can give you the spec# tomorrow if you want it but this should work for ya. Let me know.
Scott
