I am new to this forum. I got my 1977-78 1650 last year and due to some issues I found this site very helpful. My question is I just replaced the rag joints on the drive shaft by moving the engine forward as explained in a few threads. I have it back together and notice a slight whine which sounds like the hydrostatic even between forward and reverse. I seem to not remember the sound and wonder if I missed something or did something wrong. It seems to work just fine, but it does make me nervous. Any advice would be welcome.
I would use the service manual and do the hydro lever neutral adjustment. These hydro's are all but bullet proof and whining does happen with some of them.
Thanks for the reply.
The reason I replaced the rag joint was I saw that one was damaged after having problems with the tractor bogging down severely in thicker grass. But having done that, and all seemed well until the tractor warmed up it did it again. This time I thought it was the belt so I took it off to replace. Then when I increase the speed of the engine quickly it still does it almost to the point of killing the engine. Could this be the PTO itself. The 1650 always leaked some oil, and could that be the cause? |
Just a thought but could the new belt be too tight?
![]() Quote:
I would be looking @ engine cooling as you state it is oily,-- read collecting clippings, chaff etc, in cooling fins. Also check timing, & carb high speed fuel adjustment. A 1650 is a power house and should pretty much do all that is asked of it. |
Wonder if you have a bad bearing somewhere. Could be running too lean too. Also check if you have anything wrapped up under the deck like twine or fence wire , been there before.
You need to be more specific about what you mean by 'bogging down'.
Is the engine slowing down? Or is the engine maintaining speed but the deck is slowing down? Or is the engine and deck maintaining speed, but the tractor is slowing down? |
Tags |
drive saft, hydrostatic, rag joint |
