Old 05-27-2011, 10:39 AM
Pencek Pencek is offline
Default Runs but not good
I am new to this and not sure I am in the right place. I have a 782 that will start and run but not very well. When sitting on the seat the plug on the right side is black, really black all over. I put a spark tester on both plug wires, then connected them to the plugs. It looks like I have a white spark to both plugs. I thought I would have a blue spark. The spark to the right side is harder to see. It looks like the plug wires and coil are all orginial. I have though about replaceing coil, plug wires, points and condenser. Anyone have any suggestions? Oh, I do have new plugs in it. What should the points be set at?
Old 05-27-2011, 01:14 PM
JeffD JeffD is offline
Your KT17 has a broken rod.
782 w/Honda power
129 stock for now...
100 basketcase
Old 05-27-2011, 03:37 PM
young enthusiest's Avatar
I agree. Compression test it. (put thumb over spark plug hole and crank)
Old 05-27-2011, 08:53 PM
jbollis's Avatar
jbollis jbollis is offline
I am not disagreeing ,and I am always wanting to learn. But please explain to me how you can tell that an engine has a broken rod from the information the poster has given us.
Sold everything but one.
Old 05-27-2011, 10:28 PM
ljones's Avatar
ljones ljones is offline
If it did have a broken rod would you not hear a massive knock?
Old 05-27-2011, 11:35 PM
ad356 ad356 is offline
well my thought is that since its a twin it would continue to run with 1 completely broken rod but only on one cylinder. there would be no knock because the rod is completely broken. im not sure if he has a broken rod, but i agree that a simple finger over the hole test would confirm of deny a broken rod. take spark plug off of other cylinder while doing test test. test at cranking speed more than fast enough.
