wanted to make this out of channel iron like I was instructed to but I tried to drill into the channel iron that I got at tractor supply but could not get a hole into it (spent $60.00 in different drill bits) So I gave up. I used this metal I had laying around instead. I just wanted some imput to see if every one thinks this will work or am I going to kill myself. How much pressure is clutch spring holding?
It's gonna flex a bit, but with a stock clutch spring, you should be alright. The stock springs are about 250-300#/in. of compression.
I guess I'll give it a try this weekend and see if it works. I still have to get the clutch off the tractor. I am in the begining stages of setting up a shop don't have all the right equipment. I have to go out and buy things as I go. Any tricks to drilling in channel iron. My jig saw cuts through it like its butter but When i drill it it won't even mark it . I've tried slow, fast speeds oil as i go. Cobalt bits, high speed bits,tried it with a small bench press and a hand drill. I'll keep you posted
matt G I finally got the cluch out and the tool worked fine. like you said it flexed but worked. If I would do this all the time I would make a better tool. Thanks for the imput
Here is the clutch tool I use to rebuild clutches:
![]() ![]() Clutch spring is compress....ready to remove pin ![]() Business end on my punch I use to remove pin ![]() It was purchase from Sears. |
I like your set up it alot easier to work with. I look at the spiral pin punch set at sears fri $19.99. but couldn't use it when i was trying to removal pin in shaft to remove clutch to short. I didn't think about afterwards to remove the spring and other parts. will go back and get it for my tool box. Thanks for the imput.
