Old 02-27-2011, 07:15 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default Quietline rear lift question
Is the rear lift (IHCC 3pt) the same on all wide frames, or is the Quietline series different? I just picked up my grandpa's old 1250, and it needs a rear lift for my tiller. I know, I know, I'll get some pics up soon
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 02-27-2011, 07:17 PM
They are the same, with the exception of the 82 series. The 82 series uses two Frankenstein mounting bolts to hold the cast lift onto the tractor at the top. The 1x8/1x9, and QL series use a 5/8 rod all the way thru the cast lift. Also the Lift bar is going to be different between the 82 series and the other wf's.
Old 02-27-2011, 07:47 PM
The later QL tractors also use the frankenstein bolts.
Old 02-27-2011, 08:11 PM
steve59's Avatar
steve59 steve59 is offline
Matt is correct. I took the hitch off my 1282 that required frankenstein bolts and put it on my 1450 which did NOT require frankenstein bolts. If the upper pin slots have spacers welded to the inside of the frame, you won't need them. If it doesn't them you'll need frankenstein bolts and they are pricey.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 02-27-2011, 08:01 PM
Cool, I didn't know the later ones used that. Thanks guys.
Old 02-27-2011, 08:14 PM
so if need be I can put the lift from my 1450 on the 1250 until I get the 1450 running. Gonna need a motor rebuild, ignition switch, pto switch, and possibly neutral safety switch. Would like both running before next winter to put the blade on one, and the thrower on the other.
Old 02-27-2011, 09:50 PM
If you need Frankenstein bolts don't buy them from whoever is selling them, I can make them up quite a bit cheaper than others sell them for. Please give me some advanced notice though, I'm terribly behind right now.
Old 02-27-2011, 11:16 PM
ihnick's Avatar
ihnick ihnick is offline
i welded bushings on the frame of 1650. this is before i even new about the frankenstine bolts lol
Nick.
Old 03-01-2011, 02:02 AM
Originally Posted by Wild Bill View Post
bridgewatertek: You need to look at the upper casting mounting location on the tractors frame. If you have 'bushings' welded to the frame, you need a 5/8" rod through the top casting. If you do not have bushings, you need the Frankenstein bolts. The top casting is the same for either style of ways to attach it to the tractors frame.
Where the jam nuts are, would be the bushings welded to the inside of the frame rails, if it were an older QL.
Bill I just went and checked mine and I have the bushings welded in place. Thanks to this thread I know I need the 5/8 bar but how long should the bar be? I assume that it's held in place just like my 122 er opps Allen's 122.
Great thread I've learned alot. Going to be helpful when I go to install my spring assist.
Old 03-01-2011, 04:27 AM
ajgross ajgross is offline
Inactive Member
the pivot bar is 11 9/16" long. The center of the hole on each end is 1/4" from the end of the bar. Each hole is 1/8" diameter. Or if you just want to buy one, I'll sell you mine for $10 to your door. I have one and have no need for it.
AJ
