Old 01-19-2011, 12:06 AM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Battery Dead
So I got a new battery for my 127 like 3 months ago, and it has been fine ever since. So for the first time today, it was DEAD !!! has 6volts reading. Put the charger on it and its not charging fast at all, the amps are still up there not coming down fast at all. the other thing is the tractor has been starting very lazy, I check all grounds and even put an extra ground cable on it. LAzy slow starting. SO for ha ha's I cranked it wit the charger on and she spun up FAST, and started with a few seconds !.
I think I have a bum battery......... Plus I took charger off and it reads like 12.6v then the volts start to drop.......Its off tractor on bench........
Bum Battery?
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 01-19-2011, 06:23 AM
I would have that battery checked..!!!
Old 01-19-2011, 06:53 AM
Default Yep
Yes I am bringing it today back to the store. It's only a few months old. I actually just took off all the ground wires too and VR and used my angle grinder to really clean up all the ground spots too. Hopefully that will also help a bit with the lazy starting. I also added a extra ground wire from the starter generator to the battery.
1969 Cub Cadet 127
#2 IH cart
48" deck
42" Front Blade
IH wheel weights
Old 01-19-2011, 08:44 AM
mmzullo mmzullo is offline
Check for a stuck VG also.
