What is the easiest way to put on decals on a wide frame? I heard to use Windex on them to move them?
What model wide frame is it? and do you have the old ones off/ have a picture refference? Quiet lines are a little harder to do. If its a later model wide frame they arent as tricky. Windex helps you move them before the final stick and use a plastic scraper or credit card and gently work the bubbles (and Windex) out. Also use masking tape to help hold them in place. This is how i learned to do decals.
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
It is a 128. Thanks for the tips
Don't use too much of the Windex, a little is all it takes. A mist instead of a dripping wet surface. Also warm soapy water is good. Wash the surface the decal will be applied to with soap and water, especially if it's new paint. Be sure that the decal has it's protective cover on the shiny side (surface facing up that you'll see when done) to protect it from scratches when you squeegee as you remove the air bubbles. I have applied decals to models Original up to the 1650 and all have turned out fine. Just take it slow. Some of the covering may need to be trimmed before you apply the decal. If so stay close to the edge but be sure not to cut into the decal. Squeegee the moisture away and let the decal alone for awhile (allows moisture to dissipate) Take your time peeling it off so you don't peel the decal off as you go. And most of all HAVE FUN:biggrin2.gif:
well i got the decals on but i didn't have Wendex but i got them on and they turned out great thinks for your help.
Anytime, and it sounds like you Got-er-did, MrGitrdone! hope to see some pics of it soon. I did my decals "dry" but still turned out great. realy made my 123 stand out!
![]() Quote:
Gives ya time to slide around & position & easier to get out the bubbles when ya finish of with a credit card. Nik, |
Thread Tools | |
Display Modes | |
