I broke a bolt on my deck adapter, #323 I believe. The bolts that attach the 2 parts of the adapter look like they might should be shoulder bolts. I only have the one shown and it's a regular 3/8 bolt. The only parts diagram I can find is at Partstree and the don't identify the bolts. Their probably NLA but I thought I would see if I could get some guidance on what to replace them with.
Cannon |
Later today, I will look at one of mine and see what it has.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Under 1864 it shows both bolts as shoulder bolts.
The short one is 938-0108 1.45" Long one is 738-3100 NA 1.76" long I use the hardware store shoulder bolts and add a washer if needed.
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
Thanks. I'll try to match something up from the hardware.
Cannon |
I picked up 1 1/2 and a 1 3/4 shoulder bolts at the hardware yesterday. I used a flat washer on the 1 1/2 bolt. I used a grease needle to put some grease in the mule drive pulleys and it ready to put back on the tractor. Thanks
Cannon |
If your mule drive bearings were dry and not smooth before greasing, I would be sure to keep an eye on them. Check to see if they feel hot after mowing. If a bearing seizes up, you will probably end up replacing your pto belt.
If they feel hot, replace one or both with some good quality pulleys with smooth bearings. Bad bearings will put a strain on your engine and decrease power to the deck. Pulleys are usually welded and not serviceable, so a word of caution here.
| Thread Tools | |
| Display Modes | |
