Hello Everyone,
I am a young IH enthusiast and got my first tractor, a Cub Cadet 100, from a fellow member of my tractor club. So far I have disassembled the wheels, the hood and front grille and several ancillary components. I plan on doing a full restoration on this tractor. I have a question about the rear axle endfloat, the left hand side was excessively dirty compared to the right which tells me there was a leaking oil seal. Rocking the hubs in and out, the left side hub moves 1/16th of an inch and the right side hub moves about half of that (1/32nd of an inch). This is a rough estimate done with a ruler, as I don’t have a set of micrometers or dial indicator gauge yet. Does this sound excessive, and how can I tighten it up? I do have new seals from IHCCW, but not sure if I need new bearings or dive into the transmission. I have a separate issue with the transmission (some gears don’t engage with the clutch pedal depressed), so I might have to rebuild the whole transmission anyways. I appreciate your help! |
Don't worry about that little bit of end play. If you remove the cover at the back you'll see that the axles are held in with a C clip and they can move in and out a little. You can down load service manuals here.
https://www.onlycubcadets.net/forum/...splay.php?f=19
![]() Quote:
There's a lot to be said for "not fixing what's not broken"!
That's a really nice looking cub. I'd certainly not rush to "restore" that one. There's a lot of restored ones, but only ONE that looks like yours. Thanks for the pics and welcome here. ![]()
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
X2 on leaving it original!
I have two of them now and a new 102. I like the "original" as-found look also. Save your energy and $ for tires, clutch, carb.
A 122 with weights and a deck for mowing trails. 100 with loaded ags, three point for ground engaging brinly cultivator, brinly disc, thatcher, cart and snow plowing. 100 with weights for wood hauling. Rusty functional 102 with rear lift. Elec Trac E15 for finish mowing. |
Thread Tools | |
Display Modes | |
