It has always been my understanding that the M20 had a 1 1/4" PTO shaft size, which was an odd ball and took a special (much more expensive) PTO clutch. I've discovered the one I have that came out of a Cub Cadet 2082 originally has a 1 1/8" PTO shaft just like my M18 does. Are there some out there that were 1 1/8", or is mine an odd ball somehow with a non Cub Cadet engine/crankshaft in it? Or do I have an M18 masquerading with an M20 ID tag, and M20 decals on the engine tins?
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
I have a 2082. I will try and find an easy way to check it. Might be a few days or weeks, it is too hot outside to do anything here in Tennessee.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Don’t go tearing stuff apart to see. It’s more of a curiosity than necessity. With that being said you might be able to tell by taking the bolt off that threads into the shaft.
I have two 2072's, both have 1.250" shafts.
2072 owner |
Thanks, if Roland were still here he would probably have solved this by now.
I found some interesting info, I'm going to dig out my calipers and go check both of my engines. Maybe it's not engine specific but Cub model/size specific, According to this below, the Supers with Magnums used 1 1/4" and non supers (KT and Mag) used 1 1/8". I never actually measured mine, but I ASSUMED the M18 would have been 1 1/8" because I've never had one that wasn't, and this one came off a 1711 repower. I just know my PTO clutch fits both of them. See below: Warner Front Electric Complete PTO Assembly 1 1/4 inch shaft P/N 717-3043 USE 917-3043 Fits 1872, 2072, 2082 Warner Front Electric PTO Assembly W/ Spacer #1 1 1/8 in. crank P/N IH-144720-C91, 717-3003, 717-3044, 717-3038 Fits 682, 782, 784, 1872, 2072, 1050, 1204, 1210, 1211, 1282, 1535, 1541, 1710, 1711, 1712, 1806, 1810, 1811, 1860, 1862, 1882
I just confirmed both of my engines, the M18 and M20 are 1.125” shafts. Both came off Cub Cadet tractors too.
Thread Tools | |
Display Modes | |
