So to start out, I have very limited knowledge of these tractors so I am learning everything as I go. I do however have decent knowledge of how things work and have what I would consider myself "Mechanically inclined"
Here are a few more photos. The mower deck as mentioned above is is pretty bad shape and Im still trying to determine if its worth messing with or not. It seems to have some pretty bad pitting but no holes. Its missing some covers and a few parts that were pinned from the factory were replaced with bolts and nuts at some point. I have started taking it apart to see exactly what I have to work with.
Nice purchase. Looks solid and all original. The mower deck is worth keeping. Those are one of the better ones built. Have fun on your rebuild!
Justin |
Try to save your Carb. The Chinese ones are hit and miss, mostly miss. Some are ok, some not. Just my experience.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Ohh yea I’m not throwing anything. I’ll probably buy a new one then once I’m done I’ll rebuild the stock one to have as a spare.
First of all, welcome to OCC. You made a good choice picking a 100 to restore. I’m a little partial to the 100 since it’s the model I learned to mow on about 35 years ago and I still have that same exact tractor. Your deck looks to be in better condition than the deck was on mine when I rebuilt it. Mine had 2 trashed spindles and pulleys and several rust holes and cracks in the shell. My 100 has been down for the last 5 years while I rebuild and paint it. I hope to finally get it finished this year, fingers crossed.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
I have made some progress the last few days. I have decided to get the engine cleaned up and ready to go before I go any further on the tractor. I did find out the motor is from 1995 so its defiantly not original. The only problem I'm having is the fins are so rusty, I'm having a hard time deciding how I should go about cleaning and prepping them for paint. I also have found the vinegar is a great cheap way to clean parts but it isn't much help for removing paint. If anyone has a recommendation for a good paint remover let me know! Thanks for all the replies.
Welcome to OCC! Great choice, you can’t go wrong with a vintage Cub Cadet.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]() ![]() |
I assume you mean the fins on the head??
Don't paint the fins. No one will see them anyway and paint will impede cooling as well. |
I have been held up the last week or so going back and fourth with my local Kohler dealer trying to get parts. I ended up just cutting my losses and decided to just order online. The only real reason I wanted to get parts from a local place is ease of return if parts don't work but these old motors are just simply too hard to find parts locally and cost an arm and leg compared to the online sites. In the end $150 later I have all my gaskets, belt, spark plug and wire, new carb, and air filter. Hopefully next week will be more productive!
Tags |
100 restoration |
Thread Tools | |
Display Modes | |
