Im looking at buying a cub 70, I will be using it for plowing with a brinly plow, potato plow and cultaivators how hard are these to lift with the lift lever with the spring assist? thanks dale
You should be fine with a spring assist.. Even without you'd be OK if not doing too big of an area.
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever! ![]() |
I used a manual lift for a plow without spring assist, but I'm 16 so it wasn't a problem to do half an acre. I have a spring assist on a different tractor, and if majes lifting a monstor like a tiller, easy. You won't have any problems!
Tyler Chiliak. Southeast Alberta Canada. My dad and I own, 1650, , 1450, 1250, 1250, 1200, 982, 782, 149, 149, 149, 128, 128, 123, 100, 100. Also a 1310, 1500, and 2 1600 IHC trucks. |
I have a spring assist on my 122, and even when it is tightened as much as I can the plow is a tough bugger to lift after a few passes...but I drive for a living and my arms ain't what they used to be.
Probably I need to dismantle the spring assist and clean up the threads so I can tighten it more?? It gets to a point and stops tightening, only twists the spring..
Quietlines and narrow frames, mostly projects but I mow with a 1200 and have a 122 set up for pulls. Wandering the country bringing towers to wind farms everywhere, and bringing yellow stuff home to Texas. Also into flatfender jeeps. |
Thread Tools | |
Display Modes | |
