Old 07-14-2017, 01:54 PM
IaHawks's Avatar
IaHawks IaHawks is offline
Default K301 no spark at points
I'm working on my k301 on a Cub 125 and having a some problems with the electrical system. Tractor ran 5 years ago, replaced battery condenser and points. Engine turns over but no spark at spark plug and no spark at points. Was thinking maybe bad coil but if you touch the points with a screwdriver/anything metal with key turned on it will spark, making me wonder why there is no spark if the points have juice. I took fine sandpaper and rubbed both points to make sure there was no coating and have the gap set to spec. Any ideas?
Buy American made Products!
Old 07-14-2017, 02:17 PM
Go here to help you diagnose the Basic Kohler K Series Ignition Circuit.... http://www.onlycubcadets.net/forum/showthread.php?t=27
Old 07-14-2017, 09:03 PM
IaHawks's Avatar
Very helpful diagram. However everything looks correct at quick glance, I wondered if maybe an improper ground from the condenser or points could cause it but I don't see how this could be possible as the points are attached to the engine normally and the condenser is in the standard brace. Things like this make me think about switching to electronic ignition sometimes lol.
Old 07-14-2017, 09:07 PM
Point systems are the simplest form of ignition there is.
Just do your checking and you will find the problem.
Old 07-14-2017, 10:34 PM
You need to verify wiring is correct. Here's the link to diagram
http://www.onlycubcadets.net/forum/showthread.php?t=35
Points shouldn't have spark at them, make sure you deglaze the points. I know you said you did but make sure. if wiring correct then Buy a cheap 12 volt test light and test for positive at positive post of coil during start. If present, next step is, While starting, probe negative side of coil while starting, test light should flash. If it stays on constant, points aren't closing properly, if light is not on at all, coil is open or points aren't opening properly and coil needs to be replaced/points adjusted. Let us know your findings.
Old 07-14-2017, 11:07 PM
Had that on a Kohler 16 on an Ariens had to replace the coil, points condenser plug and wire due to corrosion before it would fire. Thing had sat for who knows how long..
