As many of you know, I've been working on adding hydraulics to my 100.
I'm using a GM power steering pump running off the back of the engine. To get the rotation correct the pump had to be turned around and I made a jackshaft and used 2 belts to run the pump. Right now I have the relief valve in the pump set at about 700 psi ![]() ![]() ![]() ![]() A 2 spool valve off of a JD 317 garden tractor. ![]() It will be mounted under the seat since there's nowhere else to mount it where it won't look awkward or be in the way. ![]() The lift cylinder will be on the left side of the dash tower because there is not enough room on the right side with the pump there. I had to cut a 3/8"x6" slot in the tunnel for an arm to attach the cylinder to the new rock shaft. ![]() This is a pic of the cylinder arm attached to the new rock shaft. ![]() Here is the other side of the rock shaft attached to the 3 point lift. ![]() This is the lift bracket for my front blade. I'll have to do some work to my lift rod to clear the pump bracket. ![]() I still need to make a clevis to attach the cylinder to the rock shaft and make the deck lift arms to weld to the rock shaft and then finish welding everything together. Routing the hoses and trying to make it look clean may be the hardest part of this project. There isn't much room to run the hoses inside the frame.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Great job, Adam! Thanks for sharing your pics.
Thanks guys.
Made a clevis for the cylinder. The end of the rod has been broken off and welded back on so I will try to clean up the weld and make it look a little better. At least they welded it back on straight. ![]() Mounted the valve under the seat and started plumbing it. Need to make the hoses from the valve to the lift cylinder yet. I'd like to add a filter to the return line if I can find a small one. ![]() New rock shaft. Need to make the pins for the deck lift arms and finish welding it. ![]() ![]() Started making the levers for the valve. Have to make a bracket for them to mount to and pivot on. They're just mocked up for now. ![]() ![]()
That is some mighty fine work!
Co-Founder You only need two things in life...duct tape and WD-40 If it's stuck and needs loosening, use the WD-40. If it's loose and it's suppose to be stuck, use the duct tape. |
OK - I have the PS pump, can you fabricate the rest?
Kubota B7100 HST 4x4 w/FEL, 4' Bush Hog, Woods RM400 Finish Mower Original Member #54 |
Thanks. I made the pullies.
I am really impressed with your system. It seems obvious to me after reading your thread that you are a machinist since you were able to make some of the parts needed for this project. So my question to you is would you be interested in making another set up and selling it? I would be interested if it is something you would like to do. If you are than please contact me at alaskan_extreme@hotmail.com. (I live in Nebraska not Alaska as my email may deceive). I would need a turn key system because my skills include taking it out of the box, bolting it on, and adding fluid. Thats about it. Let me know what you think. |
Awesome setup! Great craftsmanship!
To many ideas, not enough time..... Cub Cadet 147 2050041u340160 Cub cadet 129 main mower Cub Cadet 1811 Cub Cadet 1872 with 60" CCC deck. Many Mower Decks, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" and 12" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade. |
Thread Tools | |
Display Modes | |
