Old 03-18-2016, 06:36 PM
Lucky Chow Lucky Chow is offline
Default Tell me something good --- Spindles need replacing
I've got a couple of noisy spindles. These are the two outside spindles that the short blades operate on. I believe I have a 42 inch deck, although the plate is missing and I'm guessing based on blade lengths. I need to either get these repaired or replaced, depending on if they are the rebuildable type or not. Can someone dentify these and advise me what I have?
Darryl
IH Cub Cadet 125
Old 03-18-2016, 07:02 PM
Those are rebuildable. remove the bolt in the center of the pulley and the pulley will come off, once the pulley is off you remove the key and then the shaft will slide out the bottom. Depending on rust it might be a pita but they're easy to work on.
Old 03-18-2016, 07:04 PM
Those are the rebuildable type,all spindles on that deck are the same,only the pulleys are different.Those look like 48" spindles,any way you can take a pic of the deck?
Old 03-18-2016, 07:20 PM
Good eye Lew, I agree those look like 48" deck spindles.
Old 03-18-2016, 08:09 PM
Sure thing. Here's the deck.
If you measure this deck on top from one side to the other, it measures 48 inches.
Darryl
IH Cub Cadet 125
Old 03-18-2016, 09:41 PM
That's a 38" or 42" deck.
The 48" spindles have a thicker casting just above the tin cup.
Old 03-18-2016, 09:57 PM
Yep it is a 42" deck.
now you determined it is, what parts you need?
