Good morning folks. I'm about to bolt up the 12 horse Kohler on the New ISO
mounts, Is there a Torque spec for the 4 bolts that go into the Aluminum oil pan? All I can find in the service manual is the ISO Bolts/Nuts @ 20 ft Lbs thanks and have a good weekend Dave
![]() 1976 Cub Cadet 1200 & 44A mower 1964 Cub Cadet 100, No Attachments at this time, I do have a cart to pull stuff around. |
the dealer said to 8 ft lbs mount to frame
![]() I have no idea what bolt the dealer would be referring to. The bolts that run through the iso-mounts are not a torqued bolt, and on the older engines, (solid mounted) the spec would be much higher. Sounds like the dealer guessed.
[QUOTE=J-Mech;323287]Why is everyone always so concerned about torque? If there is no spec listed, then no need to worry. So.... no there is no spec. Just make them tight. I also suggest loctite on those bolts. If you absolutely need a spec, torque them to 20-25ftlbs. Depends on how good the aluminum is, and how long of a bolt you have.
![]() I have no idea what bolt the dealer would be referring to. The bolts that run through the iso-mounts are not a torqued bolt, and on the older engines, (solid mounted) the spec would be much higher. Sounds like the dealer guessed. [/QUOTEMy At my cub cadet dealer the guy in the parts department has A 1450 cub cadet And was saying that cub cadet did a sevice bulletin on the ISO mount. I see that he's talking About the oil pan so never mind
I've read about some folks tightening them a little at a time until the least amount of vibration.
I torque the iso-mount bolts (rails to frame) to 8-10 ft lbs or until the rubber bushings bulge appropriately. Use nylock nuts so they don't come loose. Then torque the oil pan bolts to about 30 ft lbs. If it's an aluminum oil pan, don't over tighten or you risk stripping them out. I've found a bunch of aluminum oil pan bolt holes stripped out. Heli-coiled 3-4 different engines.
| Thread Tools | |
| Display Modes | |
