Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 04-14-2015, 04:41 PM
Husker Husker is offline
Default Risk in boring a K321A?
I took my block in to the machine shop and was told it wouldn't be worth the cost to have it rebored, as they've seen a high rate of cracking. The guy seemed to knowledgeable, but I'm also concerned he doesn't want the hassle. He advised I just get a new block. 1. Do I tell him go ahead and bore it and accept the risk? 2. Any advice on where to get a replacement block? I emailed Cub Classics sponsor to see if he had any on hand, but haven't heard back yet.
Old 04-14-2015, 05:15 PM
Member Don Vogt would be the one to ask. BTW....you did NOT mention the size of the increased bore...!!!
Old 04-14-2015, 05:35 PM
Merk Merk is offline
I would find another machine shop providing it is only being bore up to .030 over. He doesn't want to mess small engines.
Project Uncle Dick
Cub Cadet 70
Old 04-14-2015, 06:41 PM
I agree with merk, it just sounds like an excuse to get out of doing it.
Old 04-14-2015, 06:49 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
did the engine ever throw a rod? if it did you have to look the starter side of the block over real close and at the bottom of the cyl where they break a chunk out. sometimes a crack extends out of that area up to the into the cyl.
the only other spots I've seen them crack is on the head gasket area towards the PTO end of the crank. they like to blow the head gasket in that area and for some reason the 14 block cracks there pretty easy. I've also seen the 14 block crack at the cylinder the 3rd cooling fin down. You can usually see the cracks so just look it over close
Old 04-14-2015, 08:54 PM
I assume the block can be magna fluxed to check for cracks?
Tags
149, block, bore, k321
