Hi everyone,
I have a 782D that I was plowing with a few weeks ago. As I was going from forward to reverse, the tires stopped turning (either direction) and the plow dropped all the way to the ground. The engine was running fine. I can't figure out the problem. The engine starts and runs great. It just won't transfer any power to the wheels and the hydro lift for the plow/mowing deck doesn't move. I checked the assembly from the lever on the dashboard to the transmission and everything is intact. It only has 465 hours on it. I bought it with 416 hours on it 2 years ago. I'm not sure when the hydro fluid was last changed, but I never changed it. It's not low on fluid and there are no leaks. I had no problems with the lift or transmission before this problem. Any help/advice would be appreciated. I was looking to sell the tractor, but I need to get this issue straightened out. Paul |
Check the driveshaft.
I lost track of what I own a long time ago! |
I'm not completely up on my knowledge of 782s but I do know that if the drive shaft quits then everything from the engine back quits. On the older models there are spiral pins that can break causing the same issue- check to see if this is an issue.
Clogged filter or problem with the relief valves (stuck?). I would start with regular service of it by changing the fluid and filter and then pull the check valves and inspect them.
Check valves sounds like it would cause symptoms. I think if it were a driveshaft/pin issue the plow would not have dropped but maybe I'm wrong
Does it even have fluid????
| Tags |
| 782, 782d, hydro, hydrostatic |
| Thread Tools | |
| Display Modes | |
