127 amp gauge constantly fluctuates in the positive range at anything above idle. I'm not accustomed to seeing this level of needle fluctuation since my O does't have one. Voltage reads 14.5 at the battery fast idle. Gauge? Regulator? Or normal?
I just got the charging system on my 107 running tonight and have had the exact same issue. It'll bounce all over the charge side for awhile until I slow down to idle. Then it goes all the way to discharge for about a second and then centers out to 0 until I speed it up again.
1966 Cub Cadet 122 1968 John Deere 110 1968 Cub Cadet 104 1971 Cub Cadet 107 1975 Cub Cadet 1650 2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree. |
I think I've narrowed this down to regulator vibration. Don't know if I am missing some dampening rubber on the regulator mounting or not or if possibly the cubs require something unique about their regulators to tolerate the vibration. Any further insight appreciated.
I think you are on the right track. I had that on a 129 I bought which had totally dead battery. The owner started it, but only with a 100 amp charger and the V.R read zero so I was not confident about the charging/regulating. When I got home with a good battery the regulator was flying all over. I put a spare V.R. in and it read much steadier and positive. could be the adjustments letting the vibration open/close things when they should not be?
Gophred 2 - 1811's with 50C decks, one mows the other is waiting on deck, 129 (my sons retromod)-, hydro lift, custom 3 pt with a trailer ball , foot pedal speed control, used for trailer hauling. 129 (mower) 42" deck, foot control, 1810 with 44C - next in the slow death march of mowing the camp. a few 1200 series parts rigs. 2017 Kubota b2650 loader mid mower. |
![]() Quote:
My 127 bounces all over the place from discharge to charge at high idle. I'm not sure if my charging system is working correctly or not. The s/g is fresh and the v/r is supposed to be good, but that is questionable to me.
I am with juicy and the dampening rubbers on the v/r. Is there supposed to be some there or not??? |
Thread Tools | |
Display Modes | |
