Old 12-13-2013, 03:24 PM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
Default 149 starter lube?
Hey guys, first of all, I'm sorry the pics are sideways. I cant figure out how to flip them. ( any help on that would be appreciated). Anyway, I just got this starter and I see a hole on the back of the starter on the top that seems to go all the way to the inside of the starter. I have heard that some of these need to be lubricated but I am not sure if that is correct and if it is then what do I use and what is the frequency? Also, I have to keep it covered outside all year long and I am wondering if that hole should be covered? Thanks for any help, Mark
http://www.onlycubcadets.net/forum/a...1&d=1386965528http://www.onlycubcadets.net/forum/a...1&d=1386965936
1973 Model 149
42" Snow Blade
John Deere X360
John Deere 10 cu Poly cart
Squire Applegate 5HP recoil start
Old 12-13-2013, 03:37 PM
That is a very clean 149 you have there!!! Interesting....Mine have flaps on them. I use a single drop of 10w30, about once a year, to lubricate them up. Once I used more than that and it didn't start, so someone on this site advised me to only use one drop instead of many. You could get a little rubber stopper to put in it to keep the moisture/dirt out of it. Others might have different advice for you here.....but what I told you has worked for me for the past 10+ years.
Old 12-13-2013, 04:31 PM
jimbob200521's Avatar
That's why I love this site, I never knew that!
Edit: So I'm guessing this applies to all starter/generators? I've got a 129 with a 14hp Kohler transplant and the starter turns kinda slow, I've never lubed it so I figure it might be worth a shot? :-/
-Ryan
Old 12-13-2013, 06:43 PM
The ones on the original were able to be oiled.All the others were sealed.You can buy caps for the one you have.
Old 12-14-2013, 09:08 AM
Thanks for the compliment on the paint job CubCadet123! It's really more of a 5 footer though. The closer you get the more mistakes you can see. I used spray cans and it was the first time I tried painting one. I am happy with it though. Thanks also for the info about the lube. I will get a rubber cap for it next day I'm off. It's turning over and starting great so I want to keep it that way! Thanks again,Mark
1973 Model 149
42" Snow Blade
John Deere X360
Old 12-14-2013, 09:36 AM
Let's see some pics of your 149.
