Hey guys i need some expertise and maybe a miracle...
My 1450 which i have not been able to get running (well), so i finally brought it to my buddies shop (he is a John Deere dealer). Anyways he through another carb on my tractor and she ran fine! So they want to sell me a carb for $325. well i would love to throw a new carb on, but i dont have the money to. So my question is: can i fix this carb? He said it is worn out and she is getting too much air in or something. Or should i try and find a used carb? if so where? Also, on my coil the bottom nut is stripped and the nut will not stay on tight anymore. What can i do? I appreciate all your help in advance.
1977 1450 Hydro -At the Shop! and a 582 Special on torn down on the bench. QA42A, 2 44 decks, snow blade, trailer. |
It is hard to say without knowing more info, but I would guess that it is getting too much air around the throttle shaft? Which there is a couple of different fixes for it, but really need to know more.
![]() Quote:
as long as you are at it, get a rebuild kit for yours and have some fun!!! |
I think it's the main throttle flapper. It moves up and down.
![]() Quote:
at that price it should come with more than a kiss...
For that much, it ought to come with an included o-ring!
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
For that price, it should come with another tractor!
John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
Keep us informed about the bushing repair! Good luck!
try to see if its a carter or warbro ,if warbro,dont fool with it .and get a carter , 26 or 28 or number 30 ,look in side the bore of the carb ,and it should say one of the numbers listed ,if it has numbers in the 50s ,its a warbro .now if your carb is leaking around the throttle shaft ,it can be repaired ,with a bushing ,or sometimes with a plastic washer .there is a brake down ,how to repair this in the kohler manual .hope this helps .David
Thread Tools | |
Display Modes | |
