Ok Guys,
So I hear this cast iron Kohler weights in close to ~200 lbs. I don't have a cherry picker handy. I was thinking of making an braced frame on a pickup truck bed post with 2X4 and then using an eye through the Hang man sort of L. Can then use a 3/8 rope and do a double or tripple loop so it works like a crude block and tackle. Any easier ideas.. easy , quick and cheap. |
...Or just grab a friend...
I have a beam exposed in my garage, that I tie up deer for butchering. I have a hook installed in the wood. I was thinking drill a horizontal hole through the beam, and put a pipe through, and hang a chain. Then, a come along or a boat trailer winch. That would work for deer, engines, or lifting tractors for tires.
http://www.harborfreight.com/1000-lb...nch-65688.html |
Get 3 2x4's and make a tripod. Then use a come along.
I am no "weight lifter", but, I have no trouble lifting a complete engine from the floor to the tractor.
I ain't gonna hold it there for a half hour!! ![]() Give it a try, it might surprise you!! ![]() |
I lifted mine out of the 1450 & I'm 60. Take everything off the engine u can.
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift. ![]() |
Sounds like I need to round up the neighbors son (25) whom is quite strong.
Thread Tools | |
Display Modes | |
