Old 10-08-2011, 01:30 PM
rsierra1025 rsierra1025 is offline
Default Headlight bezel on 1450
Do any of you know if that's aluminum or that pot metal? Mine is cracked, was going to try JB weld on it. If it's aluminum I would take it to a shop (but I'm sure we aren't that lucky)
Old 10-08-2011, 01:55 PM
If you're talking about the round, black things that the headlights are mounted in, those are rubber.
Or are you talking about the nosepiece that the hood is connected to? If so, that's aluminum and could probably be welded by someone with a TIG welder.
Old 10-08-2011, 02:26 PM
Default Headlight
Yea, the piece around the headlights.....in front of the tin on the hood.
http://i89.photobucket.com/albums/k2...5/DSC_0985.jpg
http://i89.photobucket.com/albums/k2...5/DSC_0984.jpg
Old 10-08-2011, 02:44 PM
I would JB Weld it, a lot less after weld body work. No concern about thermal distortion.
If there is room inside in a "hidden" area, add a piece of steel JB'ed in place across the joint and it will be stronger than new!!
And it is CHEAP!!
Old 10-08-2011, 04:02 PM
westofb's Avatar
westofb westofb is offline
I am pretty sure it is aluminum, I have one a PO has welded where it cracked, looks to be aluminum to me.
Jeff
Brookfield, MO
________________
Old 10-08-2011, 04:23 PM
bocephus1991's Avatar
I would Have it welded if it were me
Brian
