I wanted to pass along my method of adding an analog tachometer to my 682. There are some Wheel Horse posts on connecting a tachometer to the alternator so I thought I would try it and it worked!
I purchased an Apex Tachometer from ebay: http://www.ebay.com/itm/Electronic-C...72.m2749.l2649 Dip switches get set for alternator, 8 pulses / revolution. I attached the signal wire to the right side of the tractor voltage regulator + lead. Power came from the hour meter power and grounded to the steering frame. Checked motor RPM with hand held tach and I am within a few rpm. Fit right into the hole for the hour meter. I moved my hour meter to the tunnel cover since the plug would reach and I don't need to monitor that constantly. Hope this helps someone else try it. |
I have wondered if you could run an alternator tach. Good to know it works!
![]() Thanks for the post! |
Thanks for the information and write up. Since the Quietline Series of tractors use the same Stator and V/R, I assuming it would work the same.
Cool! Great writeup!
![]() How long did shipping from India take?
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
The tachometer only took a few days to get to Northern OH from India. Much faster than the auction said. I had to email the seller to get the dip switch settings sheet.
Thanks for the write up! Looks great!
Yep they do! Mine is running on my 1650 since December 2015...
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
I ordered mine on 08/27/17 and FedEx delivered it today. 12 days and $44.00 to my door, not too shabby. I'll get some pics and update how it works in my 982.
Ordered mine last week when i posted. still have yet to see it. Any chance you know what to set the dip switches to? I wonder if you can set them to run off of starter gen engines using the coil. similar to how Kirk Engines tachs work.
I think we all got yellow fever at this point. |
![]() Quote:
It was not the case with my 1650 tachometer but I already knew that and after I take a good look at the diagram I substitute one resistor for a 10 turn 1/4W potentiometer, now it's accurate but who really need a RPM on a garden tractor? For what purpose? For me it's was just a fun totally useless project but it may look cool on my walk behind snow blower. ![]() A simple rule...Keep the gauges and diagnostic tools on the bench or in the toolbox. For mowing and snow blowing a good beer holder is all you need ![]()
