I have a bunch of worn rod ends on a 2084 I am working on and while it's apart I want to replace them and tighten up the steering. I intend to replace the ends on the P/S cylinder and both ends of both tie rods. From what I see for the parts blow up, all the ends are 1/2"x20 female thread but there is no mention if they are right or left. Will probably order them from McMaster-Carr unless my friend at the race shop can get me a better deal. Going to get the heavy duty greaseable ones since they are cheap enough. I may get them for the 2086 while I am at it.
They should all be right hand thread. All the tie rod ends on my 1572 are right threads.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
I just looked at the tie rod ends and the inner doesn't look like its 1/2" its much smaller. The outer looks like it may be 1/2". I'm sure somebody has been down this road, any insight on the correct ones I need to order?
Well, you could always look it up......
http://www.partstree.com/parts/?lc=c...&dn=0035800040 My bad, it doesn't say. But it does give a size for the jam nut for the tie rod. It's listed under the #7 listing for the tie rod itself. Process of elimination. |
If your thinking of using the Heim style, they can be had with oil impregnated bronze bearing surface.
Or a PTFE liner instead. The HEIM joint wipes the bearing surfaces clean when it moves. If you use a non-stud type HEIM joint directly bolted with a bolt in the eye, then the movement will be restricted. Use the stud style HEIM joint. As inexpensive as they are, I would not use the greaseable type. Your just inviting dirt and grit to hang on the part that does not work well with such. |
