Old 09-05-2014, 09:46 PM
Calvins66Cub's Avatar
Ha ha Sam. I've been trying for a 123, but the guy is stuck on $600. Engine needs rebuilt. I'm stuck on $300.
Someday maybe.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 09-05-2014, 10:11 PM
Someday maybe.
Meet in the middle at $450
At one time I had a 122 and a 125. Now I have two 125s
Old 09-05-2014, 10:14 PM
red56turbo's Avatar
Not the answer you want to hear, sell the 122 and buy a hydro. No gears to mess with.
Ha Ha! Agreed!
Josh
Diesel Cub Cadets...........
Old 05-20-2019, 09:57 AM
Compton21's Avatar
Compton21 Compton21 is offline
I have the same issue with my 100 as well if I back up an incline matter how small it pops out also my 3rd gear does it too the gears also make a slight grind when going in and sometimes you gotta push a little hard on the shifter
Old 05-20-2019, 10:09 AM
cooperino's Avatar
Compton,
You will be best off starting your own threads rather than replying to these old ones. Your specific issues and symptoms may be different than the previous posts.
Old 05-20-2019, 02:35 PM
ironman's Avatar
ironman ironman is offline
Take the shifter out by removing the 8 small bolts holding the top plate and lifting out. Check that the two bolts numbered 12 in the picture. They lock the forks to the shifter rods. If they loosen, the forks slide on the rod and don't get the gears completely meshed.
Old 05-20-2019, 09:33 PM
You will have to split the tractor to get to those shifter mounting bolts.
Old 05-20-2019, 09:40 PM
cooperino's Avatar
The ones in my 126 loosened up once. I didnt need to "split" the tractor. I just took fenders off. #12 bolts
You do have to split to get the slides out number 13
Old 05-20-2019, 09:49 PM
The ones on a 100 are on a low tunnel frame not like a 126 with the taller one, you may get the front ones out but you will not be able to lift the shifter out.
Old 05-20-2019, 09:51 PM
Not that there needs to be a “chime-er-in-er” but, What he said.
