I have a leaker from the shaft seal, and I have searched the forum and can't find any information on the subject other than replacing it with a new one. Has anyone disassembled the steering hydraulic cylinder to rebuild it themselves? I rebuilt a lift cylinder for my old Jacobseb GT14 Hydro that was a welded one just like this. I opened it up very carefully with a sawsall
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Taking it to a shop is the best thing to do. I have no idea how you ever cut one open with a sawzall, welded it back together and it work. If you don't weld the cap on straight, it will gald the rod, and leak. After watching you fix things on here, I also have to say that for some reason you are one of the most lucky people on earth. You should play the lottery.
![]() ![]() Seriously, please don't hack up the cylinder. A welding shop should cut it open and weld it back together for you for a small price. You can rebuild it, just have it cut and welded on a lathe. The seals are o-rings, they can be gotten out of any $25 red box o-ring kit that you buy at a parts store. You don't need to "source" them. |
Here is a link but not much info. I know Kelly did one. Please report back on what you used and pics would be nice too.
http://www.onlycubcadets.net/forum/s...ht=cubs+boxers
![]() Quote:
![]() Anyhow... The one I did before I cut from the bottom end weld, not the top. When I put it back together I clamped it in a vice and squared it up with a straight edge and then tack welded it and checked it again before welding it the rest of the way. it was pretty much perfectly straight. I'm not sure how taking it apart at the back can cause anything to be thrown off for the shaft to cause wear. I can see how cutting the top off could risk that happening. Also, the one I did before took two seals in opposite directions on the piston. I already have an assortment kit of new nitrile O-rings. There is a welding shop right down the road from me, I will check into having them do the cutting and welding. I didn't think of that option, so that advice was helpful.
Proof that if you sift through Jon's rant's you can find helpful information.
![]() Quote:
![]() Quote:
sorner the rod and piston do not have seals they are o-rings and you should be able to go to an auto store and just match the old ones with new. I've done at least 4 cub power steering cylinders in the past and they are pretty straight forward. I think I would find a local machine shop and have them cut the weld off. Sawzall is pretty primitive and I would think a much higher chance of failure. ![]()
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Awesome. Thanks. I was only going on what I’ve seen before that had actual seals in them. I’ll find someone to crack it open and close it up.
I wonder if you can use a heavy duty iron pipe cutter, you know the thingy that goes round and round till it cuts through to do the job instead of the sawzy all?
![]() Quote:
I used a big one of those to cut the 6 inch diameter pipes filled with concrete to put in the basement between the halves of modular homes to support them. Worked great but “Low man on the totem pole” literally.
