Old 04-14-2016, 08:27 AM
Nice work Steve! Put the cam follower in a drill press or regular drill and take a grinder and dress it up. It doesn't need to be perfect. Here is one that I did and it worked fine.
Attachment 73883 Attachment 73884
Chunk that plastic piece in the garbage and get a used front wheel bearing or most hardware stores sell cheap bearings in the nut and bolt section. I think it's 1 3/8 OD but measure to be sure. Gonna be a nice little unit when you get done.
Todd he's working on a Cyclops, the plastic piece is fine on these steering box's. They have a CV joint just above that bushing so they don't get any side to side load.
Steve fix or replace the follower as Todd mentioned, replace to 2 ball bearings and the foam seal. You can make a seal out of closed cell foam. I have a roll of this stuff so this is what I use.
http://www.lowes.com/pd_13281-236-10...=50071521&pl=1
Old 04-14-2016, 09:00 AM
Ooops! I forgot this was a Cyclops. I use the same foam that Sam does too and it worked for me. Here are the bearings and cone that you will need. IIRC they changed the cone a little. Has anyone had any issues with them fitting in the Cyclops column?
http://www.messicks.com/part/ih-71930-c91/kit
Old 04-14-2016, 09:30 AM
I'm not positive but I think the Cyclops box is a little different. This is what Cub calls for.
741-3021 RETAINER/BALL ASSY $17.92 ea
http://www.greatoutdoorpowersports.c...UT//741-3021/1
703-1029 CUP-BEARING $4.99 ea
http://www.greatoutdoorpowersports.c...UT//703-1029/1
That said, normally the "Cup" doesn't need to be replaced. What usually happens is that the plastic spacer between the balls fails and the balls move to one side.
Old 04-14-2016, 09:50 AM
Dirty Steve's Avatar
Todd and Sam, as always- thank you for your knowledge and input! I was looking at the rebuild kits with the IH-71930-C91number that include the 2 sets ball bearings and the cups but was concerned of changes between a Ross steering box and these CCC boxes. This one is stamped CCC. I will order parts from local dealer. They have been real good on prices so far.
If I had access to a milling machine and good machinist I bet they could turn the end of the cam follower stud and reuse it. I don't have anyone I the area however.
Old 04-14-2016, 10:46 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Steve,
Just in case you don't want to fix that cam follower... Jeff in PA makes cam them for the Ross box... I'm sure he could whip one up for a CCC box... I believe the only diff is they are a bit longer
Looking good!!
Jay
Proud owner of the following:
Old 04-16-2016, 10:11 PM
Got the front and rear crank seals out. Parts did not make it today. Probably Monday. Pulled the steering CV joint out and cleaned the old knarly grease out. Applied new grease and put it back together. Then I cleaned the 42 inch deck. Paint is deteriorating but no holes in the deck. Sharpen the blades tomorrow.
Old 04-17-2016, 01:56 PM
Local cub dealer had both grommets for the bottom of the fuel tank in stock..... some gas line, clamps, alot of elbow grease later.... Then a new hydro filter and some Hytran Ultra. Oh, got the blades sharpened too. This rabbit hole has done got too deep.....
Old 04-17-2016, 02:09 PM
Looks like it is coming along, won't be long before you are cutting some grass. While you have the motor out I would change the gear on the starter,easy to do now.
Nice deck by the way!
Up to 530 and counting...
Old 04-17-2016, 09:50 PM
jaynjeep's Avatar
Looking good Steve... I've been there done that many times on the getting in too deep part!!
That's what happens when you try to fix something right and the previous owners didn't care or were patch artists!!
But when you are done, somebody will have a nice tractor!!
I'd be tempted to keep it!! I have that problem too often!!
Jay
Old 04-17-2016, 11:04 PM
Jeepers Jay, those couple sentences read like a book I would have wrote.
Steve, that tractors looking good, sure you're not going to keep it?
