Old 06-16-2009, 01:37 PM
jkier's Avatar
jkier jkier is offline
Default 127 issues...
Well I made it look nice...
I was having a grand ol time mowing the lawn yesterday. Feeling pretty spiffy with my shiny 127 when it started acting up.
The engine started sounding stressed on slight inclines so I backed off the speed control until I was barely moving. I was moving at a pretty good clip for a while (trying to beat the weather) maybe it was starting to overheat?
Also, I noticed a bit of a *clunk* going from forward to reverse. i know that wasn't there the past couple of times. I know I've got to check the fluid levels in the hydro..
Old 06-16-2009, 09:25 PM
67hydro's Avatar
67hydro 67hydro is offline
jkier
Maybe the clunk is in the drive train,drive shaft.Check where it hooks to the engine and rear,past the flex disk on the rear.Maybe the roll pin has things wore out.
When the engine sounded stressed did you notice any difference in speed,I supose you would being you stated you were on a slight incline,but did it sound stressed on the flats and did you notice any speed changes then.
Yes check the fluid levels,How were they??Last time you did a filter change?? Last time you changed the fluid???Water in the fluid??
Just a few things I thought you might want to check........
Jason
Jason Davis
Old 06-17-2009, 11:16 AM
jkier's Avatar
Thanks for the tips.
I'll be going over the whole thing this weekend..I hope.
Last time I change the fluids... hmm .. I've slept since then
