Old 03-04-2011, 06:53 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Question 3-Pole lights
My 126 has 3-pole lights in it .When I got it the wiring harness was missing .All the wiring diagrams show only 2 post on the back of the bulb. How do I wire one with 3 post on them up to see if they even work ?:bigthink
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 03-04-2011, 07:01 PM
william1041200's Avatar
on the bulb you would have a common terminal, and a terminal going to the lo beam filament, one going to hi beam filament. you could check for continuity with a meter first, or put 12 volts across any 2 terminals. It wont short- worst case is both elements lighting dimly.
Old 03-04-2011, 07:04 PM
forget the meter . duh. it should show continuity any way you connect it. unless bulb is bad ...
Old 03-04-2011, 08:16 PM
Three terminal head lamps were never offered by IH. This would be an aftermarket modification made by someone.
Old 03-04-2011, 08:54 PM
jeff k.'s Avatar
Thank You both very much this is good info. I didn't think I ever saw a bulb like this on a cub before. High n Low beams on a cub thats funny.
Old 03-04-2011, 09:29 PM
If you add another switch, like in the footrest, that would kick butt! it would be like a classic car.
Old 03-05-2011, 08:41 AM
108cubber 108cubber is offline
How about a SPDT switch? One side Low, other Hi. Just have to run an extra wire for the Hi side.
KennyP
Old 03-05-2011, 01:52 PM
jeff k.'s Avatar
worked on the lights today. Believe it or not they work high n low. I wired them up using a stock switch. To play with the high n low I just switch the wires around. The first pic is high ,second is dim . Hard to tell the diff in the pics.
Old 03-05-2011, 02:58 PM
What wattage are those lights? The high-beam setting may be more than what the S/G can keep up with.
Old 03-05-2011, 03:04 PM
jeff k.'s Avatar
I'm not sure I'll look later. I'm not to worried though they are mostly for show . I don't do much at night. So they prob won't see much use.
