Old 02-25-2013, 10:24 PM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
Default Creeper Disassembly
I thought I would disassemble the creeper that I recently purchased tonight, but have ran into an issue. The shaft/bearing cage assembly does not want to come out. I pulled the main snap ring and was able to drive it out enough that the OD of the bearing cage is almost flush with the housing but that as far as it will go. I have played with the splined coupling to try to ensure that the splines line up. It makes no difference whether the coupling is shifted in or out. When things stop moving I can still move and rotate things by hand, nothing seems biund up. I have used a small punch and hammer to try to drive the shaft out. Planetary gears are lined up and engaged with the ring gear. I hated to start beating any harder until I took a step back to make sure Im not missing something. And yes I have the service manual open on the bench lol.
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
Old 02-25-2013, 11:03 PM
I think the O ring makes it fit snug. Here is mine pulled apart and cleaned up.
Old 02-25-2013, 11:35 PM
wj-ihc's Avatar
The point where the oring would line up with the snap ring groove pretty much matches where things seem to stop moving. I guess it will just take a swifter hit or maybe get it in a press to apply a solid load. Thanks for the picture, that helps clear things up a bit.
Old 02-26-2013, 04:05 PM
TommyK's Avatar
TommyK TommyK is offline
It should pop out pretty easy. Make sure it's not hung up somewhere inside. From the pics, it looks like you have to coupler lined up right. Not sure what could be holding it up.
Old 02-26-2013, 09:52 PM
wj-ihc's Avatar
I got it. Took it over to my fathers so I could put it in a vise. Couple solid hits with a hammer and a punch and it slid right out. It was the oring hanging up.
