Old 08-25-2010, 07:56 PM
cub149's Avatar
cub149 cub149 is offline
Default 982 starter solenoind
My 982 wouldn't start today, all it does is make a clicking sound from the starter solenoid. There where some sparks coming from it also. Do I just need a new one or is there something that can be done to it? Or could it be the starter itself?
The battery is fully charged.
Chip T.
Drexel NC
Old 08-25-2010, 10:15 PM
CMA's129's Avatar
CMA's129 CMA's129 is offline
Sounds like the wire to the starter is loose.
"Good Dogs Never Live Long Enough!" Casey Angeletti
Old 08-26-2010, 06:21 AM
If all the wire connections to the solenoid are clean and tight....then I would replace the solenoid.
Old 08-26-2010, 05:19 PM
cub149's Avatar
That's what I was going to do but I think I will first check the starter to make sure it turns over. Am I correct in this process: use jumper cables and ground the battery and place the positive lead to the starter and it should turn over? If it doesn't then the starter is the problem.
Chip T.
Drexel NC
Old 08-26-2010, 05:42 PM
CMA's129's Avatar
If your seeing sparks I'll still says bad conection.
Old 08-29-2010, 09:52 AM
cub149's Avatar
Yep, easy fix. Cleaned all connections on solenoid and it hit first time. Thanks all.
Chip T.
Drexel NC
